  • 7258 Views
  • 2 Likes
atx7738
Is a Arlo Pro 2 camera backwards compatible with the Arlo Pro Base?
YES.... it will even work on the gen 1 Arlo base
Susie1057
I have the original Arlo. I am looking to upgrade to the Arlo Pro HD. It has the two way talk and siren. Do the two systems work together? Do I add my two cameras to the new base?
Arlo123
Actually you can add your old camera to the base station of the Arlo Pro. If it's only the 2 way audio that you want for the Arlo Pro, you can also sync the pro camera to your existing base since it would still work and the 2 way audio will be working since it's a feature of the camera and not the base. The only thing might not work is the siren or alarm feature since old base station doesn't have that feature.
  • 7259 Views
  • 2 Likes
