Arlo pro 2 - Can The Solar Panel Be Used For Access To Advanced Features
  • 1 Reply
  • 1176 Views
Hattrik
Can you use the solar panel and get access to the advanced features like continuous video recording and the focused motion detector options
ShayneS
Hattrik,
The solar panel will provide a trickle charge. The current design does not allow the use with the CVR feature. You will need to be directly plugged in to make use of this subscription. With an Arlo Smart Premiere Plan you will have the feature with or without a Solar Panel.
  • 1 Reply
  • 1177 Views
