  • 1 Reply
  • 1205 Views
The_drewster
Hi
Can anyone tell me if I can use a wired Arlo Pro 2 or Ultra on a badic plan? I don't require 24/7 continuous recording, just motion detected.
AncientGeek
Hero
Hero
In the case you describe, you are just powering the Pro 2 from the wall with no CVR, so it should be totally happy with the basic plan...just like a battery powered camera...or one attached to a solar panel.
  • 1 Reply
  • 1205 Views
