@StephenB Is this dependant on whether I log in to my web account or in the app? Since it works fine when I log in on the web.
Has this changed recently, since it worked fine until a few days ago, and I haven't changed any settings? How do I change between Feed and Library?
The thing is, using "Activate/Inactivate all units" (or something like that, I use swedish version) I can switch all cameras on and off, including those that say that the base station is offline. I can also reach and livestream from all cameras.
So, the only problem is that I cannot see the status of two of the base stations when I'm in the app. All other functions are ok.
You cannot migrate from "Feed" back to "Library", so you need to be sure you want to do this. In order to migrate to "Feed', you go into "Add Device" and start to add a Pro 5s camera. That won't work, since you don't have the camera. But it will migrate you to "Feed" before you get stuck.
IMO, the most serious issues with "Feed" are
- there are no custom modes, only three built-in ones. You can modify those three, but you cannot add more.
- it is not possible to get the combination of geofencing+scheduling to completely work
- if you have a subscription and have cameras in more than one location, then you will need subscriptions for each property.
It sounds like you have the "Library" interface, with "Arm" and "Disarm".
Are you using a "Friend" account on both the phone and the PC?
