Arlo app in the Iphone is not detecting the Arlo Pro 2 camera
  • 1 Reply
  • 1416 Views
Pola
Since my Arlo Pro 2 was not properly working, I deleted one of the 3 cameras. When I tried to reconnect the camera to my Iphone, I get the following error -"No Arlo devices found," even after pressed the sync button on the Arlo camera.
Also, how to reset the Arlo Pro 2 camera, not the base station?
Thanks in advance
Pola
ShayneS
Hi @Pola
Removing the camera from your base station as you did would be the reset option. What is the status LED light displaying in the base station when you try adding the camera? Have you tried using the web portal on your computer as well?
  • 1 Reply
  • 1417 Views
