Yes, i have restarted, uninstalled the app and my phone and ended tasks and retried and this is duplicated time after time.
FiX THIS!
I have certain times where the camera needs to be in a mode not to detection motion with those native options to save battery life. I should not have to turn the camera off for this as i still want to be able to manually view the camera at will.
Turning the camera OFF in setting is more of a privacy issue , like a camera in a bedroom and they are shared...turning on is then allowed by only the primary account holder.
If you don't want the camera to record, it is better and easier to just eliminate the camera from the custom modes you create... any camera NOT in the active mode is OFF.
Split up your cameras into groups as needed.
