Arlo Pro2 Camera connect connectivity to app issue
  • 2 Replies
  • 581 Views
ArloPro2Questio
my pro two camera when plugged in will not connect in the app, but when unplugged and running on the battery, only it will connect to the app
Interesting. About the only thing I can think of is to try a different charger/cable. Note that it has to be a charger that supplies both 5 volts DC as well as 9 volts if you want it to also charge the battery. 5 volts will run the camera but not charge.
BrookeN
Try removing it from the account and adding it back on and see if that helps.
  • 2 Replies
  • 582 Views
