  • 1760 Views
JsTechnot
Does the Wink 2 Hub work with the Arlo Pro 2 units. Since it works with Arlo Pro I assumed it would work with Arlo Pro 2. Any help?? Thanks!!
If the Pro works with Wink, there is no real reason why the Pro2 won't...
The Pro2 is the same basic unit with extra features when on ac power .
gray79
according to wink they asked us to reach out to netgear as of now it does not work in wink.
J_K_C
Definitely not working with the Wink2 hub yet.  Just picked up the 2 cam set today, and got one setup and configured, then tried the Wink connection and it says no cameras can be found when I try to add it.  Hopefully, this gets worked out soon.
JKC
  • 1761 Views
