  • 10 Replies
  • 2735 Views
  • 5 In Conversation
Yvesg
Hello
arlo pro 2
Looking from the front, to the right, the light is orange.
app don’t recognize the camera
change the battery, same thing
deleted the camera from the app, cannot add the camera back on .
is the camera dead?
anyone that can help?
10 REPLIES 10
A weak/dead battery should very slowly blink the amber LED, not have it on all the time. WHen you install a charged battery, does the blue LED blink briefly, indicating power is applied? Have you tried using AC power, with as well as without a battery installed?
Yvesg
First of all , thank you for your response.
no blue light even with the new battery.
removing the battery and using AC, solid orange light still on!
DannyBearAgain
The arlo pro2 front camera led showing continuous Amber is not a common indicator condition so the camera may be faulty.
Refer
https://kb.arlo.com/642/What-do-the-different-LED-behaviors-on-my-Arlo-camera-mean
The pro2 Camera led will show blue when the battery is fully charged as long as the led setting is edit: (enabled and not) disabled within the camera’s settings menu. Check.
The pro2 Camera uses a 7.2vdc battery so requires the QC charger that came with the camera to charge the battery.
Yvesg
Thank you
i’m using the Arlo charger.  No blue light 😕
i think you are right, the camera is dead!
BrookeN
Reach out to support, you get that by going in the support area of the app (not my.arlo.com), and selecting a camera in a subscription plan. Scroll down to the contact section, and you will see an option for phone support. It is available between 6 am and 6 pm US pacific time.
Yvesg
Thank you for your help
in my app, the option to call  customer service is gray because my system (canera, doorbell, hub) is no longer supported.  Bought that in 2019, no longer works, no service… and i pay an annual subscription… this is a bad business practice!
for sure that i’m not buying their products anymore. Looking to replace…
@Yvesg wrote:
in my app, the option to call  customer service is gray because my system (canera, doorbell, hub) is no longer supported.  and i pay an annual subscription…
FWIW, I am seeing that in my app, even for cameras that are not on the EOL list.
Oddly, the support area also shows my subscription as trial (which is it not).
@JamesC - can you check on this?
BrookeN
Can I get a screenshot showing the area of support that are grayed out?
Yvesg
My app is in french… see attached
thank you
BrookeN
I've opened a support ticket detailing the concerns you've posted here. An agent will reach out to you with a status update as soon as possible.
  • 10 Replies
  • 2735 Views
  • 5 In Conversation
