  • 5 Replies
  • 391 Views
qowieuryt
Can’t get my Arlo Pro 2 to resync.
I removed a Arlo Pro 2 camera from my profile and can’t get it to add back.
When I try to add from the iOS app (7.5.0), the camera starts as a slow blue blink and then changes to fast blue blink. The app keeps searching and never locates it.
If I click the dock (VMB4000) sync button and then the camera sync button, the camera starts slow blue blink then fast blue blink but it never shows up in the app.
I have 3 other pro2 cameras connected and work fine. I’ve tried swapping batteries without success. Have 2 VMB4000 docks and neither able to pair to the last pro2 cameras.
5 REPLIES 5
BrookeN
What trouble were you having with the Pro 2 prior to uninstalling it?
qowieuryt
Needed to charge it frequently. It was the farthest camera from the base so i thought it was weak wifi signal or other issue. I did swap the batteries with the other cameras and didn’t notice any difference. Thanks!
BrookeN
It sounds like all troubleshooting steps have been preformed. The Pro 2 may no longer be working and needing to be replaced.
jab12345
My cameras are not working. Will not sync.
Any suggestions?
Edinburgh_lad1
 @BrookeN were you instructed to respond to all Arlo HD/Pro/Pro 2 problems in the same way to ensure more users stop using these cameras and get new, latest generation, cameras, as this isn't the first time you've responded like that?
There are lots of other potential reasons - including Arlo's poor software that intentionally makes it difficult to connect specific cameras - why the OP may not be able to connect their Pro 2.
  • 5 Replies
  • 391 Views
