Arlo Pro 2 with version 4.19. I cannot see device settings/device utilities/camera positioning
Hello everyone, I cannot find camera positioning mode on the app. I do not see device utilities or camera positioning mode. I used to use it all the time after charging the cameras. Any help would be greatly appreciated.
Thanks!
Message 1 of 3
1,112
You can use live view instead to position the cameras. I have used that instead of the positioning mode since all I have to do is to open the app and start live view.
Message 2 of 3
1,078
Thank you for your reply. Yes, I ended up using live view also.
Message 3 of 3
1,016
