Hi my arlo pro 2 camera went off line I can not charge it hence I can not link i to the base station any ideas as ive only had this a couple of months
Why can you not charge it ? adapter? cable? ...
Or you can just run the camera inside on any 5v usb adapter with enough current, battery can be removed if need be
