Arlo Pro 2 vs Arlo Pro
I currently have the Arlo Pro cameras, and looking to add more. Here are my questions:
- Does the Arlo Pro 2 work with the Arlo Pro cameras I already have?
- Does the Arlo Pro 2 have a longer or shorter battery life then the Arlo Pro?
- I am planning to purchase the Arlo motion lights (when they come out), will those work with either the Arlo Pro cameras I already have and/or the Arlo Pro 2 or both?
- Can my existing Arlo Pro cameras be set up to be less sensitive or with the triangle peremater I have seen mentioned online?
Yes.
About the same.
We dont know much about the lights yet but I guess they would work across the board.
Dont' know what you mean about the triangle parameter.
