  • 1 Reply
  • 2322 Views
dannymurphyarlo
I currently have the Arlo Pro cameras, and looking to add more.  Here are my questions:
  1. Does the Arlo Pro 2 work with the Arlo Pro cameras I already have?
  2. Does the Arlo Pro 2 have a longer or shorter battery life then the Arlo Pro?
  3. I am planning to purchase the Arlo motion lights (when they come out), will those work with either the Arlo Pro cameras I already have and/or the Arlo Pro 2 or both?
  4. Can my existing Arlo Pro cameras be set up to be less sensitive or with the triangle peremater I have seen mentioned online?
Streak2
Master Master
Yes.
About the same.
We dont know much about the lights yet but I guess they would work across the board.
Dont' know what you mean about the triangle parameter.
  • 1 Reply
  • 2323 Views
