Arlo Pro 2 turn off randomly
Hi.
I’m so sick of my cameras and Arlo support! My Arlo Pro 2 turns themselves off every 2-3 day and do not re-connect. They are wired plus they have gotten brand new batteries, on recommendation from Arlo.
- it usually if they work too much, that’s when we’re not home and there’s movement. Then they shut off
Have any of you had this issue as well?
I have the same issues... my cameras have been replaced multiple times... I think they’re all just crappy now... over $1.5k of cameras, cords and batteries and they won’t work to save my life... tech support is absolutely NO HELP
Sadly I just have to agree. The weird thing is, I have had older models working fine. But from Arlo pro 2 and up they are so troublesome, I have to reset etc everyday!
Hi cmoore522,
Let me reach out to you via private message in regards to your experience with the support team.
Hi lumlumlej,
I would suggest to contact the Support Team to further investigate the issue you're having. You will find several options for contacting support in the provided link.
Yes please. Support is impossible to get through to, so if you are interested please contacts me by mail.
