Arlo Pro 2 system keeps dropping out and not recording and leaving gaps in CVR
I am extremely disappointed at Arlo's response to the problems I am STILL having. The way the system keeps dropping out and not recording and leaving gaps in the CVR timeline and not recording all events it is totally unacceptable.
Myself and many others (from the forums) just want a solution to the problems, whether it is hardware' firmware or software based. I purchased my system in June from QVC UK and I have talked online to an "Expert" tried all the options they suggested and I am no further on. My pleas for a resolution I feel have just been ignored. What is being done about it if anything ..... a progress report to resolve the situation would be appreciated ....... John
Mon, 23 Sep 2019
Hi johndiphyps,
Sorry to hear the problems you're having with CVR on your Arlo Pro 2 system. Since you mentioned you contacted the support team regarding this, let me gather more information from you through private message.
Did you managed to solve the problem? I am having the same issues.
Hi Phildini5,
Have you tried contacting the Support Team? If you haven't, I would suggest to do so they can further investigate this issue. You will find several options for contacting support in the provided link.
