Arlo Pro 2 station supposed to be disarmed but keeps sending emails
My station is scheduled to be disarmed but continues to work and send out emails of alerts. It's killing my battery and often the alerts have nothing on them. Is there a fix to disarm the system when you want it to shut down?
Message 1 of 3
869
Hi 115,
Are you using schedule mode or custom mode? Try deleting the modes and re-create tthem again to see if that helps.
Message 2 of 3
834
Problem resolved
Message 3 of 3
817
