Arlo Pro 2 records from 8 am to 5 pm but still records after 5 pm
My cameras are set to record between 8:00 am and 5:pm however they record after 5:00 until we go to bed. I have reset the time to record several times and it still is occuring. It is very annoying because I have to shut them off from 5 until we go to bed and that shuts off the outside camera as well. Could use some help!
Hi @alexehorse,
Assuming you are using the schedule mode when recording between 8 am to 5 pm, try to delete the schedule and set it up again to see if that helps. Try checking on both clients (both the app and the website) to make sure that the schedule times are showing correctly. Also make sure that your cameras are on the correct time zone.
Thank you Jessica, I have reset them several times and checked on both the website and the app and they are showing correctly. I have also made sure the time zone is correct so I am at a loss....
Try to reboot your Base Station to make sure that the camera and Base Station are syncing what your mode is showing.
