Arlo Pro 2 recording is blank after motion is detected
  • 1 Reply
  • 2590 Views
  • 1 In Conversation
gpmike
Controller:
HW Version       VMB4000R3
Serial number   4R058A7AB3D0B
Firmware            1.12.0.1_27940
Cameras:
HW  version       H3
Serial number   5TF18A71CCEE6                (Back)
Serial number   5TF18A7NCB497               (Front)
Firmware            1.125.11.4_29092
Night Vision ==ON
Plastic removed from camera front
Both cameras mounted outside
Both cameras on battery
Problem:
1) On either camera motion is detected
2) a recording is made and placed in the library
3) the image in the library corrrectly depicts the object that caused the recording
3) but although the recording appears to be the correct length time-wise it is blank
LIVE Mode works fine
Restarted the router and arlo control unit
Both cameras have worked fine for over a month
gpmike
It appears there was a Chrome update a couple of days ago which affected the Flash settings.  Edge worked okay.  Played with the Flash locks and now is working alright - again.  Netgear needs to moved to html 5.
gpmike
  • 1 Reply
  • 2591 Views
  • 1 In Conversation
