Arlo Pro 2 push to talk not working on Google Pixel 3 XL. Works on first gen Pixel
  • 3342 Views
dorioo
The push to talk feature does not work properly when using the app on the Google Pixel 3 XL. It does work on my wife's Google Pixel (first generation). Basically, it might work the first time but, by the 3rd message, the audio becomes garbled or never transmits. Using the push to talk on my wife's phone works without issue.
1. My phone (doesn't work properly):
Phone: Google Pixel 3 XL
OS: Android 9 - March 5, 2019 security patch level
Arlo App Version: 2.7.2_25500
2. Her Phone (works properly):
Phone: Google Pixel
3. Arlo Base Station
HW Version: VMB4000r3
Firmware: 1.12.0.1_27940
4. Arlo Pro 2 Cameras
HW Version: H3
Firmware: 1.125.11.4_29092
dorioo
After experimenting some more, I think it's working. The "issue", I think, is that I have to hold the microphone right up to my mouth for it to work. On my wife's phone, i'm able to just speak to it from a distance and have it work. Maybe it's some noise cancellation that Google is doing on my phone that warps it from a distance. Regardless, it seems to be working on my phone when I hold the microphone right up to my lips. Thank you.
ShayneS
Hi @dorioo
Have you tried to remove & reinstall the Arlo Mobile App on your phone & test again? Does this occur over WIFI or Mobile Data?
dorioo
Yes, I previously reinstalled the app and did the same just now before testing the different connections.
On my phone, it breaks over both a wifi and a mobile data connection.
On my wife's phone, it works over both a wifi and a mobile data connection.
dorioo
  • 3343 Views
