  • 4 Replies
  • 2204 Views
missymoo
Have had our Arlo Pro 2 for a couple of months, has been working well until the power cord stopped working, i had another one here that worked so used it. But for the last week realised the power light is all most on amber all the time, it does go to green, then the internet one goes green, and then the camera light goes green but then goes back to amber for about 3 minutes and goes through the motion again, so its not actually recording anything.
michaelkenward
Sensei Sensei
Sensei
If you mean the transformer/adaptor rather than just the wire into the wall, do the volts and amps on the spare power supply match those on the original?
The volts need to be correct, and the amps should be at least as high as the original. Anything less and there won't be enough juice.
Just another user
missymoo
It is model VMB4000
michaelkenward
Sensei Sensei
Sensei
Just another user
missymoo
Thanks for that, will look into it and come back with the result, hopefully
missymoo
Thank you Kudos, that worked , I had the incorrect voltage. All sort now
  • 4 Replies
  • 2205 Views
