  • 1065 Views
Bhote19
My out door arlo pro2 camera is not charging. It is plugged in continuously to the power source.
Took out the camera and brought inside and plugged in to the power and still not charging.
Was the camera plugged in outdoors? If so, what does the battery/charging icon for the camera show? Do you get an error message? WHat happens if you use the same power supply on your other camera(s)?
Bhote19
I have managed to solve the problem myself. Thank you.
michaelkenward
Sensei Sensei
Sensei
Care to tell us how you fixed it? You might save someone else from suffering the same agony.
Just another user
  • 1066 Views
