  • 5 Replies
  • 2673 Views
MimiBee
5 days ago one of my Arlo cameras stopped detecting motion. The yellow light does not light up during motion test. If I go live, I can see what I should be seeing. It continues to detect audio
5 REPLIES 5
Try rebooting the base and reinsert the camera battery to reset the camera.
KDV
My Pro 2 camera no longer detects motion either. I have read through the forums and done all the suggested troubleshooting e.i. Reboot base, pull camera battery, resync, to no avail.
Interestingly, the camera will detect sound and then record. Unfortunately though, the sound is a vehicle out in the street and not something coming up to my front door.
the motion detector test never shows the blinking amber light.
I'm out of ideas and getting quite frustrated with dragging the ladder out and pulling the camera down to resync it.
Any ideas?
MimiBee
So sorry you are having this problem too. Very frustrating. Fortunately for me, after resetting the battery and resynching the camera, the camera started working ok. Other than the support suggestions, I really have no other ideas to help you. ☹️
goldsmith49
Same issue, 4 of my 5 cameras have dropped off recently....the 1 that works I had to actually delete and reconnect and that is the one that still works. They work on live ok but whats the point, motion recording to the library is critical. There is a thread on the new Arlo Cameras also so this is a recognised issue and need to be resolved as reliability is now in question. I will re-add a camera later to test.
goldsmith49
To add to this, I have no subscription etc this is just pure recording to the USB drive, I have not changed anything in config / setup...it simply stopped working at 14:04pm yesterday on 4 of the 5 cameras.
  • 5 Replies
  • 2674 Views
