This week, my Arlo system will no longer execute rules correctly. I have a rule to trigger recording on a second camera if motion is detected on a different camera, but the second camera has not been recording. This started this week.
Any ideas?
For example,
If motion on Camera 1, record on Camera 1 and 2.
Can you delete the rule and then re-create it? If that doesn't work, delete the mode and create all new rules
Try power cycling your base station
Thank you for the reply.
I tried power cycling the base station and the motion rule still isn't executing correctly.
Creating a new mode with new rules seems to have addressed the issue. I will keep an eye on it. Thank you.
