Arlo Pro 2 motion rule not triggering second camera recording
  • 4 Replies
  • 6803 Views
arlo_guthrie
This week, my Arlo system will no longer execute rules correctly. I have a rule to trigger recording on a second camera if motion is detected on a different camera, but the second camera has not been recording. This started this week.
Any ideas?
For example,
If motion on Camera 1, record on Camera 1 and 2.
steve_t
Master Master
Can you delete the rule and then re-create it? If that doesn't work, delete the mode and create all new rules
steve_t
Master Master
Try power cycling your base station
arlo_guthrie
Thank you for the reply.
I tried power cycling the base station and the motion rule still isn't executing correctly.
steve_t
Master Master
arlo_guthrie
Creating a new mode with new rules seems to have addressed the issue. I will keep an eye on it. Thank you.
  • 4 Replies
  • 6804 Views
