  • 2 Replies
  • 2282 Views
Parrott
I love the Arlo Pro 2 for all of the listed features ( great set up, easy install, 1080p etc.) however I have one issue. . .
I keep getting continuous alerts for movement from one of the cameras. When I check the recordings and live feed, no movement
I have tried to adjust the the motion detection all the way to 1% and have readjusted the camera multiple times. Turned the camera off/on, and disconnected/ re-connected to the base. Not sure what else to do. Constant alerts are killing the battery and defeating the purpose of the motion detection and alerts. What should I do to fix the issue?
Are you changing the setting in the Motion Detection Test or your modes? The former doesn't save - it's just a test so you caan use it in your modes.
steve_t
Master Master
1. Remove the battery
2. Replace the battery
3. Put the camera in a dark drawer
4. See if you still get motion alerts
  • 2 Replies
  • 2283 Views
