  • 1 Reply
  • 810 Views
patcof2
I have one camera driving me crazy. It continually notifies of motion detected every other minute or so. Have moved twice & have motion turned down to 1%. At our wits end with this continually going off. Every recording a minute apart shows absolutely no motion. Now what besides sending it back for replacement?
Dannybear
You could try power cycling the base station.
You can also try removing the camera battery for 10sec to reset it.
Where are you setting the sensitivity, should be in the camera rules for the active mode selected.
  • 1 Reply
  • 811 Views
