All 3 of my wireless cameras quit recording over a week ago. I had charged two of them then noticed after a couple days I was not getting recordings. I can use them in “live” mode. The base station has all green LEDs. I have tried disconnecting and reconnecting base station and resyncing. I have checked motion detection and it shows they are detecting it, but they are not showing any recordings of it.
Sounds like the base station operating mode is set to disarmed. Check and set to armed mode and if armed, check your camera rules in the mode are correct, you should have three.
Why would the settings suddenly change when I haven’t changed anything?? That’s what I don’t understand. Mine just randomly stops, no rhyme or reason.
I can’t explain it either, the last time it occurred for me was with the last base station firmware update.
All the cameras disarmed and motion and audio detection indicators on the devices page cameras were all grayed out but the mode said that they should have been enabled as the mode was still armed.
Toggling the mode to disarmed and then back again resolved it.
Have you resolved it using this workaround or something else?
