  • 2 Replies
  • 786 Views
clue50
Pro 2 cameras worked fine for 2 years. Now they show offline. I have unplugged based station and reset it. I have also reset the router. No luck. Does anyone have have any suggestions? Thank you.
Dannybear
Consider if anything has changed recently in your environment such as movement of the base station or router. Also if new neighbours have moved in and setup new wifi that could cause interference. Try moving one of the cameras close to the base, say 6ft and try re-syncing.
Check that the camera batteries are not flat as a loss of connection with the base can cause them to discharge quicker.
In addition, what are the LEDs on your base showing?
  • 2 Replies
  • 787 Views
