We have had an Arlo Pro2 camera for several years, and it was possible to adjust the camera sensitivity in the app in the app under device video settings. Now, suddenly, the sensitivity settings are gone, and the unit is going off constantly from passing cars and such. Why is this setting gone?
Thank you
Third reset is the charm. All up and running again , with sensitivity settings.
So that's the definition of crazy, doing the same thing over and over again and expecting different results. But, as always, with the Arlo that's what happens.
Thanks for all your help.
https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
The motion detector test is no longer present in the camera settings page. And the armed mode setting does not offer any motion sensitivity settings, nor does it offer rules. The timed mode setting only offers timed segments, no rules are offered. I feel like all these settings were present until recently, and I used them, and now they are gone- both on the web site and in the app.
You can try power cycling the base station to start with, then progress to pulling the battery of the camera for 10sec to reset it.
Can you post a screen shot or two? Also, are you using the primary account or a "friend" account?
Hello, and thank you again.
I am using the primary account. I power cycled the base station and the camera multiple times- no dice. Then I did a hard reset on the base station. It found the base station, but continuously says the base station is offline, even though the two lights are on. Can't find the camera again because the base is offline. Wondering if the ethernet connection on the base station is hosed (but then, how was it found in the first place?) Attached are some grabs, not much to see at the moment:
It sounds like you did the hardware reset which also requires that you remove the base from your account in Settings, My Devices before it can be claimed again.
OK, removed the base from settings and did another factory reset. Now it won't find any devices whatsoever 😕
