I have Pro-2 / 4 camera set-up operating for about 2 months. All 4 cameras have shown up on my "Devices" page & I can "Live view" all cams but recently one camera has dropped off the "Mode" page which allows arm/disarm function. This is one of my inside cameras , & I believe I had previously disbled the "motion / sound " feature , but not sure. Need help as to how to reinstate the camera so it shows in "Mode" function.
The camera did not show up in the standard "Mode" segment. I took a chance & deleted that camera from my system , then re-synced it & it now shows up as before. Interesting that I had tried to just re-sync it without deleting it & did not work. Thanks
Is this for the Armed mode or custom modes? It should always be pressent in the Armed mode but if you've removed and resynced the camera for any reason you'll have to manually re-add it to any custom modes.
