  • 2876 Views
Meko923
How is the battery life? I'm assuming more features with same battery it might require charging more often?
Battery life is the same as PRO... the extra features that would use more power become active when the cam is plugged into ac
Meko923
Even with higher res or does that not effect anything?
Thanks!
BretD
Thanks to its engineering, power requirements for Arlo Pro 1080p HD are nearly identical to the Arlo Pro 720p battery life.
____
Please click KUDOS or REPLY If you found this helpful.
  • 2877 Views
