Arlo Pro 2 battery draining and night vision is very poor
Batteries draining like crazy and my night vision is very poor any suggestions?
Are the cameras maintaining their connection to the base? Or are you seeing off-line indications?
Easy thing to try is remove the camera ( remove device in settings ) , pull battery and then replace same and finally add camera back.
It rebuilds the default settings in the base for your cameras.
