Will the Arlo Pro 2 allow for more custom activity zones? It would helpful to be able to capture more than just a square and have angled edges.
I have an arlo q, for example, pointing out to my front yard, but the best position has the street running at an angle onthe image. To create activity zones that don't include cars, I either have to rotate the camera to straighten the street in the image (which makes the visibility more poor) or try and stack multiple activity zones to create a jagged curve.
So, the answer would be no, then? I was looking for something more customizable than the Arlo Q. Only having 3 axis aligned rectangles is limiting.
Yes, limiting it is. Would be nice if either edges of the rectangle can be draged in and out to create a diagonal line, or other irregular straight line shapes.
