Arlo Pro 2 Slightly Warm, fast battery drain
  • 1 Reply
  • 433 Views
mdp454
One of my Arlo cameras has become slightly warm and runs a battery down from 100% to zero in about a day.
However during this time the camera operates quite normally.
I have replaced the battery.
Rebooted the hub.
I have removed the battery from the camera for several days.
I have tried to ask Arlo support for help (Such a waste of time, they really are worse than useless)
I really appreciate from anyone that's managed to resolve this issue.
Is it possible to factory reset a camera or re-flash it's firmware or similar?
Thanks in advance
MPD454
You've done what can be done to "reset" the camera. Since these cameras are EOL, there's no support. It sounds like the camera is faulty (the warmness is likely the symptom of why the battery drains so quickly). Nothing else you can do for it other than to recycle it.
  • 1 Reply
  • 434 Views
