Arlo Pro 2 Setup Help
Have to say that I am disapointed with the Arlo Pro 2 as the manafacturer says it is an easy set-up who are they kidding?
The Cameras x 4 have synced with the base station ok but can't be found on the phone anywhere. My phone is a Samsung Android 9 Plus. I have deleted the the Arlo App twice now and started again.
Any ideas anyone it would be most useful thanks.
Verify on a computer ( https://arlo.netgear.com/ ) if it is the phone/app or the arlo system
( same id and pw as phone )
OP, you didn't say anything about having claimed the base first as the directions have you do. If you haven't done that as the first step, nothing is going to work.
