All firmware and updates have been made...these recordings are constant on 2/5 of my cameras (costco purchase). Any ideas on fixes?
Hi @how67
Just to double check, you are running Firmware 1.125.11.4_29092 on the Pro 2 Cameras & .12.0.1_27940 on the base station?
Have you tried to reboot the cameras with the issue or remove them from settings & re add?
