  • 4 Replies
  • 10637 Views
  • 2 Likes
Yolo
In the Mode tab on the IOS app, I am trying to set a rule that the siren will automatically go off when there is a motion defect on one of the cameras but there is no that option. It only allows me to choose recording or doing nothing. Any help would be appreciated.
You need to use the Add Device selection while creating or editing a rule to add the siren additionally.
Did you use the Add Device option when editing the rule?
Yolo
Yes, I also tried to add a mode but it did not help. It only has 2 options, record or do nothing.
Yolo
Got it. Thanks for the advice!
  • 4 Replies
  • 10638 Views
  • 2 Likes
