Arlo Pro 2 Local Storage Auto Overwrite Not Working
I have an Arlo Pro 2 that does not overwrite on the external USB flash drive when full. The USB icon greys out and when i check the files on USB drive it doesn't show any newer files. When i insert a different flash drive, i always format with the base unit and toggle "Automatic Overwrite" off and then on. I have tried 5 different USB drives with the same result.
Any suggestions?
Thanks in advance
Base info:
HW Version VMB4000r3
Firmware1.12.0.1_27940
Camera info:
HW VersionH3
Firmware1.125.11.4_29092
Due to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
