  • 1 Reply
  • 1574 Views
Mtam
I have an Arlo Pro 2 that does not overwrite on the external USB flash drive when full. The USB icon greys out and when i check the files on USB drive it doesn't show any newer files. When i insert a different flash drive, i always format with the base unit and toggle "Automatic Overwrite" off and then on.  I have tried 5 different USB drives with the same result.
Any suggestions?
Thanks in advance
Base info:
HW Version    VMB4000r3
Firmware1.12.0.1_27940
Camera info:
HW    VersionH3
Firmware1.125.11.4_29092
ShayneS
Due to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
  • 1 Reply
  • 1574 Views
