  • 4 Replies
  • 6534 Views
  • 3 Likes
gardeneva
I dont want to use the cloud ... can I save to my hard drive instead?
steve_t
Master Master
If your base (after being set up) is disconnected from the internet, it will still record to the attached USB drive BUT the only way to view the recordings is the remove the drive from the base and plug it into a computer and watch the clips with VLC etc. The system is designed for use with the cloud. The USB recording is only a backup
steve_t
Master Master
gardeneva
Thanks Steve - appreciated
Karllight
With a usb drive plugged in to the base station, does it record continuously or just when motion is detected?
Only when motion is detected, just like what the cloud gets.
  • 4 Replies
  • 6535 Views
  • 3 Likes
