I just bought and set up a new Arlo Pro 2 system with two cameras. In the "Settings" -> "My Devices" section, it shows two Base Stations and two cameras. The first Base Station appears to be correct and allows me to access all the Base Station settings. The second Base Station is intended from the first one and has a little symbol of a "wireless connection" in red on it. And there are no settings shown when I select it except to rename it. Then I show the two cameras below the erroneous base station at the same indent level and they both seem to be just fine. The isn't any option to remove or delete the second erroneous Base Station. I haven't seen any "double" Base Station like this in the manuals or online anywhere. Can I clean this up somehow? I've already logged out and back in, and still there.
The second base is the siren. You probably rename it appropriately to avoid confusion later.
Brian
