  • 5 Replies
  • 5199 Views
  • 2 Likes
Jeykunimitsu
Can i use a 9v and up wall charger to continuously power my arlo pro 2 with the battery removed? Its under a covered area and i live in hawaii so cold/high temps isn't a factor.
Thank you
If not charging ( samsung adapter ) you would not see the "lighting bolt" in the battery that shows charging and or it may give you a warning on screen of wrong power
If possible just use the original adapter
5 REPLIES 5
Pro 2 uses a qulacomm type dual voltage usb adapter, 5v to run...9v to charge battery.
The Arlo Pro 2 will run ( you can even pull the battery ) off of a 5v usb supply with enough current , min of 1.8a ( if I remember )
Just remember the supplied ac adapter is not outdoor rated.
Jeykunimitsu
So i should be able to pull the battery out and use an iphone brick which is 5v or my Samsung brick (9v) and run it with a micro usb and be fine? Thanks
Prob the Iphone 5v has enough current ( look at the spec on it )
the Samsung may or may not work...some qualcomm do, but the spec is tight on the cameras
Jeykunimitsu
Oh I see. Will it give a warning on the app or something to tell if it's not powering correctly? Also why does arlo not just sell a damn cord? I am aware of the recall but no other alternatives...
  • 5 Replies
  • 5200 Views
  • 2 Likes
