Armed mode has the following rule for a camera:
- If the following
- Motiion is detected
- Then do the following
- Record video
Even though I see no movement on the video, I'll assume movement happened to trigger a recording even if the video didn't capture it. After that initial trigger though, no movement occurs yet the camera continues to record--for like 5 mintues!. There is sound in the video, which maybe is causing the camera to continue recording, however "audio is detected" is not one of the trigger rules.
Are you using " record till motion stops " in your record video.... in past there have been issues.
I recommend a 'fixed' time about 1 min or so.
That's a reasonable workaround if I keep getting long recordings that will nibble away unecessarily at the battery life, thanks. Though hopefully Arlo will consider this a bug worth fixing.
