Arlo Pro 2 Charge Cable Won't Fit When Secured With Outdoor Security Mount
  • 1 Reply
  • 1209 Views
Looley
I have an Arlo Pro 2 connected an Outdoor Security Mount, but cannot fit the charging cable into the rear port, whilst it's screwed into the mount. This defeats the purpose of having a rechargeable camera. The mount where it screws into the rear of the camera slightly obstructs the port to plug in the charging cable.
Any tips?
You can remove the locking nut completely or replace it with a smaller one (1/4"-20) available at your local hardware store. Newer mounts have the smaller size nuts already.
  • 1 Reply
  • 1210 Views
