I can no longer load and view recordings that were made via my Arlo Pro 2 systems. I can see the motion detected video clips in my device library. However, when I select one of the clips and click to play, the larger video screen appears but it is blank and displays the message "Loading...". The system hangs and video is never loaded. I was able to view my recordings a week ago.
MSoft has recently done updates to Edge and another product... the update causes this.
Try Fire Fox or Chrome at this time till either Netgear or MS fixes same
