Arlo Pro 2 Can I Delete Multiple Recordings At Once?
Couple questions. Arlo pro 2 5 camera system. Is there a way to delete multiple recordings at once? I hate having to delete and confirm each individually when I know there's nothing on them I need. AND regarding "activity zones" I know how to create them - but nowhere can I find how to make them "inclusion or exclusion" zones and how they work?
How to I set it up to watch my truck at end of the driveway - yet not record every car that passes by on the street?
1) For the app, long press on one to activate the multiple selection capability, just like many other apps. For the web, use the Select link at the top.
2) Zone that don't require a Smart subscription require AC power to be active. Even then, as I recall, you can't select which one(s) are active - they just are.
Directions for this stuff are severely lacking...
