Arlo Pro 2: Cameras unable to connect to base station. Light turns amber. Tried removing battery.
My base station connects to the internet but the cameras fail to connect to the base station.
The moment i try to sync the camera with the base station, a flashing blue light appears on the camera. In about 2-3 minutes, the light turns amber for about 30 seconds after which there is no light on the camera.
I reached out to the Arlo customer support for help and tried the below options:
1. Fully charged the rechargeable battery
2. Removed the battery, connected the camera to the power source
3. Tried connecting the camera to the base station offline
I have tried replacing the system 3 times so far and running into the same issue with the cameras.
None of the options suggested by the Arlo customer support worked for me. Has anyone run into a similar situation?
Try and sync the camera directly without the app/web...
First make sure your base has internet access ( if model 4000, center led is green )
A QUICK press on the base sync button ( don't hold )
follow by a press of the camera sync button
Slow blue flash to rapid blue means it worked, amber is fail.
