Arlo Pro 2 Camera & LED Security Light
  • 2 Replies
  • 2685 Views
WillH123
Hi,
I have recently installed a Pro 2 camera looking down my driveway, which also has a LED PIR security light from Amazon installed. The camera is positioned out of range of the PIR sensor on the light, but last night the security light would not turn off. As the only thing that changed was the installation of the Arlo Pro 2, I'm assuming there is some interference from the camera causing the light to trigger. Would turning off the night vision on the Pro 2 stop it from emitting IR, and therefore stop it triggering the light? (the camera is not hardwired in, but running on battery power)
The easy thing to do is try it... tho it doesn't effect my Cam/Light combo and they are in each others range ( about 10 feet apart )
WillH123
Solved it- it turned out to be a faulty light which was randomly triggering. I only noticed it though with the install of the cameras..
thanks for for your help
  • 2 Replies
  • 2686 Views
