Arlo Pro 2 Camera although plugged in goes offline
  • 1 Reply
  • 1298 Views
ABSYD
My camera is plugged into power using the provided factory power adapter. The Camera will be working fine after a days of operation it will suddenly go offline. the app shows that the camera needs to be charged and the front of the camera the 3 LED amber lights will start flashing. with no operation. Eventhough the camera is connected to the power? If I turn on and off the power switch the camera resets itself and starts working. but it seems to have become a daily problem. Any suggestions? Also if I do nothing and leave it after about 7-8 hrs it starts working again.
ShayneS
Hi @ABSYD
Is it possible to test the camera with a different charger or the charger with a different camera?
Is the camera's battery dying or is appearing offline?
  • 1 Reply
  • 1299 Views
